Given the most recent information, I just can't see it being freeze related. The temperatures simply didn't get low enough and even if they did the freeze protection should have eliminated all of the risk. The only way there could have been any freeze damage, let alone something this dramatic, is if there were lower temperatures for longer and some section of the piping was closed off and didn't have any water flowing. So that seems ruled out in multiple ways.
By the by, I have had freeze damage in pipes that were not sealed off. A short section of the plumbing under the pump house used to be down below everything else and didn't always get blown out fully. It was open to pipe that was blown out at both ends, but still got cracked open in the winter if any water was left after winterizing.
Caretaker valves are quite capable of causing water hammer.
{Withdrawn}
Still, I can't imagine it getting up to the kind of pressures required to shatter the PVC. It should have caused a small crack at the weakest spot, not totally blown things apart. I can certainly imagine that kind of repeating stress damaging the filter housing over time, but blowing the pipes apart just doesn't seem plausible.
I'm leaning more and more towards a hydrogen explosion, despite the problems explaining the spark source. I know I'm reaching, but maybe the water hammer compressed a hydrogen bubble enough to heat it above the ignition point.
{Withdrawn}
