I have a 1980's hybrid pool that will need some renovations in the coming years. Should I be aware of the water table when draining it? Any advice for safely keeping my pool empty for a few weeks?
It says to take precautions but no real advice on what to do. Maybe it's assumed to just drain when the water table is low?? Also, surely there is some specifics on hybrids?? Thanks again
Do you have an idea of your water table? You may need to contact your municipality for information.
Do you have well points around your pool? If so do they have water in them?
Is your pool at a higher or lower elevation than the surrounding property?
Do you have any lakes, ponds, streams near/on your property?
