Dolphin active 40 gets stuck on main drain cover
gnhand
147
East Hampton, NY
Hayward Aqua Rite (T-15)
I just purchased a Dolphin active 40. It constantly gets stuck on the main drain cover. I tried tuning off the pump for the main drain which helped somewhat. I purchased the zodiac unibridge main drain cover (on Amazon $76). I tried it with no modifications. The dolphin had some success but still got stuck. So I took prior advice and removed the unibridge from the pool , and then used a jig saw to cut the center out. Walah!! The dolphin has now been transversing the cover 100 % of the time. Had this not worked I was considering returning the dolphin.
Moved from here.
Attached are two pics. It’s hard to see but I cut out the center from the cover.
