Since 2015 (second video) six reported cases of a filter "exploding," which they don't do, though they will fly apart (older video so likely a few more cases), yet seldom seen in any news reports. Daily US traffic accidents; 19,900+ with an average of 99 fatalities.
Yes, trapped air will cause the issues seen. I've seen a tank clamp fail on a system that was only full of water under pressure. The lid lifted about 2", water went everywhere, but no "explosion" as there was no trapped air under compression.
First video was either a clamp loosened before air was released or not properly tightened (instructions are on the clamp itself) when the pump was started. Operator error. I know two local pool techs that have been hurt by doing the same thing.
Second video, again trapped air and a chemically damaged retaining nut. Operator error.
Third video, again trapped air. Also, those tank clamps have rarely been known to fail if not tightened completely to the lock/stop. They will loosen on vibration until there is not enough of the clamp holding and what is holding will fail.
In both the second and third there is also an IFCS that causes the pressure in the system to swing widely as they change from port to port. They also, usually, have larger pumps that can sustain that higher pressure. Flex something long enough and it will fail. If you've ever watched a filter on a system with those you will see it grow taller and shorter with every port change.
In Chrysboy68's case, I'd recommend a new service company that won't try to scare a person into making a change without pointing out exactly why something might be needed. Changing a filter because it
might fail is not reason enough unless there is some damage somewhere.
