- Apr 10, 2018
- 5,163
- Plaster
- CircuPool RJ-45
I would start with three cases (12 gallons). I'm sure you'll need more, so don't be afraid to buy more. I assume it will also be your primary means of chlorination after your slam.
Read the slam article carefully. When you first start, you'll need to test frequently to make sure the chlorine is holding. As all of your CYA is depleted, it's possible you have ammonia. We'll know once you begin adding chlorine. You want to test and dose before bed and right when you wake up. Chlorine will be consumed quickly during the day. You'll need to test every couple hours at least until you get a feel for how much chlorine is being consumed. Use the search function and review a few slam threads.
