IMason
0
Do you have a crank shaft on this? How do you roll it manually if you don't. Thinking of rigging this up for our pool. Thanks!
My pool is nearly the same size at 20x45 and the roll does tend to get uneven but not so much that I can't roll it. My roller is at the end of the cover. Is yours in the middle?
I plan on putting a roller at each end with a rope that has hooks. I can then roll and unroll the covers more easily.
So you have to roll 40' of cover? I think it would have worked better cutting the cover into two sections 20x20.I made one (actually two) for my 20x40 pool... I cut the cover length-wise. The cover that I bought has seams every 4', so I cut along the seams. Thus, there is an 8' section and a 12' section.
I can't seem to find any foamcore ABS here in Quebec... Would it be possible to use standard ABS and shove some pool noodles in there to help with the flotation? Would it make it too much of a good place for algae to grow?
Just be careful because not all DWV pipe is foam core. Also, sometimes it is called cellular core.
