G
Guest
Re: VOLLEYBALL NET ROPE ANCHOR THING
Yup. Usually the plasterers install them though. If you make the hole they should be able to install it for you. You run the risk of having it "out of elevation" if you do it.
You sure you want it? Great place for algae to grow......
n8scstm said:I forgot to have this put in when they did the shotcrete. Can I chissel out some of the shotcrete and epoxy, or cement this in so they can plaster around it? What should I use?
