Currently strongly considering a SWG, but having a little trouble figuring out the correct size, and the differences between the various models. Currently 10k gallon pool is very stable/clear and no issues with chemistry. keep CC at 8ppm with CYA 50, add 32oz of 10% bleach daily to replace ~ 3ppm chlorine loss, and 8oz muriatic acid a week to take it from 7.8 to 7.5. TA pretty stable at 80, CH around 400. Currently run our main pump 10 hrs day at 1750 rpm.
Trying to find the right size SWG and lb/day capacity needed. Best I can figure, i need to add 4oz of SWG chlorine a day to maintain the 3ppm loss? so a CORE 35 is 1.4lbs/day so i'd need to run it 4.28 hrs/day to get the 4oz? Is that correct? Any issue supplementing heavy pool days (dogs+extra people) with liquid chlorine on infrequent basis?
And really can't figure out the difference between the various model #s for circupool. Due to my DIY skills and the controller/display built in i'm leaning towards using a CORE model (it looks idiot proof installation wise). I notice a lot of people go for the RJ model. Any particular reason?
