Hello, I’m new to TFP. First post so forgive me if this isn’t the right place.
I have a Hayward, EC 40 DE pool filter. and a one horsepower pump. My pool is above ground and is about 3000 gallons.
Last year I didn’t winterize the pool. We had a lot going on and the pool stayed open and the pump and filter connected all winter. Come summer, the case for the Hayward was cracked so I had to replace it. After doing so and cleaning the fingers and putting new DE. Everything ran fine temporarily.
My issue is as follows:
every time I turn on the filter, it runs appropriately for about 5min and then the pressure coming out of the return dies down significantly. It happens gradually over the 5min. I’ve taken out the fingers multiple times, and hosed them down.
I have soaked them in acid overnight and then put them back in which made the duration that the filter works longer.
Now it’ll work for like 20min before dying down slowly.
I even went as far as taking apart each finger and soaking the finger cases in soap and acid for 3hrs and then putting everything back together. They looked fine, no tears or anything.
Same thing. Over the span of 20-30min, it dies again. I noticed that when I turn it off and pump the handle and then turn it back on it runs for a little longer before dying. When I look at the pressure gauge, it reads about 18-19 at the point that the filter pressure dies.
At this point do I need to replace the finger cases? Or can it be something with the pump? It’s not that complicated of a system but I can’t figure out what it is. I thought for sure after soaking and cleaning the fingers it would work properly.
Any advice is appreciated thanks!
