I was just wondering what the community thinks is a normal loss of fc daily in a hot tub. When not in use mine will usually drop 4-4.5 ppm daily. I also don’t have a large bather load. Typically just my wife and I a few times a week and sometimes two children. Does this seem like a lot or pretty typical. I did purge my pipes before the last refill with Leslie’s spa purge. However I didn’t use a pipe cleaner or let the water drain through the the tubs drain plug. So maybe I have biofilm? I record a .4 ppm combined chlorine level whenever I check so I don’t appear to have nasties populating in the water. Also my cya should be 30 and that was checked 2 weeks ago so I doubt it’s changed much even though I do top off weekly.
