I have a small crack in my acrylic/fiberglass in ground pool step. What is the best method for repairing the step? I have seen where people have drilled some large holes to refill the sand underneath the crack and then repairing the holes with fiberglass patches and then painting the fiberglass. Would you need to gel-coat the fiberglass first, then paint with epoxy paint? I have a vinyl lined pool that I am not replacing the liner. I have repaired the crack successfully for the past two swimming seasons but the repairs are only temporary. I had a good bit of water leak out of the pool over the winter. I want a permanent solution without replacing the steps!
Thanks for your help!
