Saltwater pool
30,000 gallons
elevated hottub approx 1500 gallons??
Built Spring 2019 (6th year)
Mid dark plaster
Basic problem: PH keeps rising even when water is not circulating.
Did a test yesterday, PH around 5PM was 6.8. This morning at 5AM the PH was 7.2. The pump was not running.
Last year when I closed this pool, the PH was 6.2 (deliberately) when I closed it, and 7 days later I peeled the cover back and took a reading at above 8. I'm using the drops to test this. Below is my water test from Yesterday. (I can post my water tests from the pool open if it would help).
Latest Tests:
FC: 3.6
TC: 3.64
Combined Chlorine: 0.04
PH 6.8
Alkalinity 79 PPM
Adjusted Alkalinity 72PPM
Calcium Hardness 364 PPM
CYA 25
Iron 0
copper 0.10
PHosphate 1721 PPB (spring around here, can you tell?)
Salt: 3.227PPM
Temp 80
Calculated CSI -0.88
I've had white build up on the dark plaster for a number of years. Last year the pool guys came out and used three gallons of Muriatic acid in the hottub to remove the sharp crystals and white stuff that built up over winter. (The pool has had this build up over winter the past 4 years, it's just getting worse).
This year, when I opened the pool, I expected the hottub to be destroyed, but also found for the first year this happened, the crystals growing on the main pool itself instead of just having a white powder at the bottom of the pool. There were even crystals growing on the black rubber innertube that I had in the hottub to keep the cover elevated for rain water run-off.
What could be causing this constant PH rise?
Yes it's a salt water pool. Right now the Salt control head exploded due to ants and isn't even connected (it's in my garage on my workbench). The ozone system has also been disconnected after I read many comments on these forums about it not being needed. (Immediately saw a reduction in chlorine demand, imagine that). This year I have NOT been running the water feature much at all, except to exchange the water in the hottub once per day. I'm still seeing massive PH rise even with the salt and ozone systems disabled and no visible aeration when circulating the main pool. Runtimes are approximately 4 hours per day at this time of year.
30,000 gallons
Mid dark plaster
Latest Tests:
FC: 3.6
TC: 3.64
PH 6.8
Alkalinity 79 PPM
CYA 25
Iron 0
copper 0.10
Salt: 3.227PPM
Temp 80
