A month ago I returned from vacation to find 2 collapsed pipes on the pergola where the solar collectors are situated. Only on the outlet side.
I had left the solar collector valve a little open just to have a small amount of flow through them.
After entering the house and checking the pool I noticed water had been dripping down from the pergola (where the coupling came a little lose). Went up to investigate and to my surprise, I found these 2 collapsed pipes!!
I have communicated with the solar collector's supplier and the pipe manufacturer. They still insist a vacuum release valve was not necessary.
They had never seen this happen before. Pipes are the correct spec for pool piping.
I am logically thinking that a large vacuum and excessive heat had caused this.
Maybe my fault for leaving the valve just slightly open , the bypass causing a negative pressure effect on the outlet of the collectors possibly?
The piping is good to 60c and the panels 90c+.
A very rare occurrence.
I leave the valves fully open or fully closed now. Still pending to install a VRV for now. 65USD here is not cheap.
Fixed the piping section last night at least to regain the full flow.
Thanks
Thanks
