Scaling will be a whitish-colored film over your fixtures and your liner, especially along your water line. It won't be slimy, but will feel a bit chalky. I did a quick search on "scaling" because I know I saw some very good photos of scaling, but couldn't find them. You can use the search function at the upper right area of the forum page and see a lot of good info on scaling.
You may not have scaling, but your pool water may be at just the right point in its chemistry to get some calcium carbonate precipitate floating in the water, which would give it a cloudy or milky white appearance.
With regard to the overnight FC loss test - I would keep the pump/filter running so that there is total mixing, but others may have other opinions on that. I know my tablet chlorinator can put chlorine in the water even when it is dialed down to zero, but yours may work better.
Anonapersona: his CC is zero, so I think his shock has done the trick - I suspect his FC level was higher before he received his test kit - but, lightingguy recommended an overnight FC loss test to confirm, which i agree is a good idea.
