- Feb 6, 2015
- 6,169
- Plaster
- CircuPool RJ-45 Plus
Re: main drain has dirt and debri sitting in the bottom-no suction?
The measuring cup doesn't measure by weight (one pound of stabilizer will fill a measuring cup a lot more than a pound of lead - it's a density thing) - but Pool Math does show by volume also. For CYA, look on the top line - the first figure is by weight and the second by volume.
Put the test results in a Word doc or on a piece of paper - either way will work.
In addition, you can post them here as a record of your progress. You may also consider taking a picture each day - at about the same time, same angle and same location - of the pool to post here as an easy way to see your progress. It is suggested to take a pic of the steps to see how the clarity improves - frame it so the top step, lower steps and the pool bottom near the steps show. Your pool really isn't too bad, so you may not see drastic improvement on a daily basis, but it's good to have those pics to see where you started and the end result.
This morning you said the FC was 18. But after we discussed it, you stated you forgot to divide by 2 - effectively giving you an FC of 9. Anyway, you do need to test FC tonight and add chlorine to get to 12 if necessary. Each and every time you test, add chlorine to get to shock level of 12 (for your specific CYA). And brush at least once daily.
Kim, thx! i went ahead and eyeballed it as I did not know the oz on the measuring cup could measure weight as well but I'll use the cup for next time. I was wondering if we needed a separate cup for MA. and to answer your previous question, I am not taking records so i will make sure to record all of this on a word doc unless anyone has a better method. thx!
