I am looking to add an SWG to my pool.
Considering the Circupool Edge40, but certainly open to suggestions.
I have seen others post about using a timer switch with an SWG for fine tuning chlorine generation.
What I am curious about is, does "cutting power" to the SWG reset or change the settings? If you "unplug it and plug it back in" (in my case using a relay or timer), do you have to manually press the on/off switch to turn it back on, or will it revert to previous state after power loss?
Perhaps it makes more sense to put a relay in parallel with the flow switch, rather than cutting power if I want to "turn it off"?
