Hello,
So I'm new to managing my pool chemicals. Pool (12x24) is almost 3 months old and has a saltwater generator, and has a screened enclosure. First two months the pool contractor took care of maintenance and I recently took over. I just got through a couple of days of heavy rain and thought we needed to check chemicals so I check on the reagent Chlorox test kit until my Taylor K2006 SALT arrives. Added 5 drops of reagent and chlorine side turns very bright yellow so thought it was high based on that.
I took a sample to Pinch a Penny and got the following readings:
Total Chlorine: 0
Free Chlorine: 0
Combined Chlorine: 0
PH: 8.0
Acid Demand: 4 drops
Alkalinity: 80
Calcium Hardness: 500
Stabilizer: 30
Salt: 2800
They told me to add some muriatic acid (4 cups), stabilizer (2 pounds), and put my saltwater chlorine generator on boost mode and keep it running to see if chlorine goes up. I did all of those things.
I also bought the strips and on those ones it also reads 0 or close to 0 chlorine readings. Anybody have any idea what could be causing this discrepancy or am I doing something wrong? I thought the saltwater generator was used to keep chlorine levels at acceptable ranges. I had it at 50% as recommended by the pool builder is it not working? I'm just worried with this whole situation. Is this normal or does this happen a lot after heavy rain? The pool looks really good to be honest I don't understand could something be wrong?
Total Chlorine: 0
Free Chlorine: 0
PH: 8.0
Alkalinity: 80
Stabilizer: 30
Salt: 2800
