Update from Sunday.Is there anywhere that algae could be hiding in plain sight ? Ladder rails, light niches, autofills, the foam on the back of the skimmer door, etc etc etc.
Did a OCLT overnight. Chlorine loss was 5-6ppm. Also did a test at pool shop this morning to confirm, my testing levels as follows:
TA 135
pH 7
FC 3.6
Salt 3900 (have now added 60kg of salt)
CH 327
CYA 44
Phos 0
To give context to above results.
- 10 days ago I completed a slam. Had no chlorine loss over night
- only changes since then was to add 2kg of CYA using old sock and 8kg of calcium. These chemicals were added last week. Re CYA the 2kg was added to existing level of 40ppm (so I have not got any real increase). CYA would be at most 1 month old
- maybe 2 swims since slam.
- only added a small amount of water.
- water is crystal clear, no signs of algae. I have limited places it could be.
It seems bizarre to get such large chlorine loss only 10 days out from a slam with no real change since slam was finished.
