I wanted to bump up my calcium by about 80 or 100 ppm. I did so late at night, several hours after topping off the chlorine to 6 ppm. In the morning the FC was essentially 0 ppm. I added enough liquid chlorine to bring it back up to 6 ppm, then a few hours later it was around 1 ppm. Finally after a 'standard' shock (SL without the AM) things seem to be back to normal.
We did have ~5 kids in the 3800 gal pool that day before I topped off the FC, so I assumed it was some type of mass urination event, even though these same kids have been in there a couple times without any prior problems with the FC. Then after searching the forums I see that I am not alone in this experience. Might have be the calcium, possibly contaminated with organics.
I have plenty of the suspect chemical left in the bag. I might do a mini controlled experiment on some water in two buckets, one with a fresh dose of calcium, to see if the FC drops overnight in that one.
Anyway, I don't have any real questions about it. Just documenting & sharing here.
UPDATE: See post #29 for my controlled test
