After watching my pool guy have a very easy time managing my pool for 2 years I wanted to start doing it myself so I really understood what was going on (& help keep costs down).
Just a bit of background. I have a 10,000 gallon pool with cartridge filters & an electric heat pump located in Phoenix AZ.
I know the summers out here can be a bit challenging on pool care with the temperature & the sun but I figured why not take on a little challnege for myself.
In terms of chemicals I currently have a big bucket of Clorox chlorine tabs from Costco & the Clorox shock packets (both were handed down to me by a neighbor moving out).
Since I wanted to get a baseline I took a water sample to Leslie's & this was their attached report. His first recommendation was to lower the number of chrloine tabs I float from 3 to 1 (he said pool guys float 3 because they only come once a week) and floating 1 would help with chrloine numbers. He also mentioned that my CYA was high because of the Costco tabs (& their high concentration of CYA). I did notice that these chrloine tabs do seem to last less time than the ones my pool guy uses.
He sold me on some metal removal chemical (because we back up to state land and have lots of pollen falling into the pool on a daily basis). He said to use that & shock after the sun goes down, do a filter cleaning and I should see some improvement. Also recommended a drain & refill over the winter.
So my question is what chemicals (& other products) should I have (should I switch from tabs to liquid chlorine) in order to maintain my pool given the test results attached.
Please let me know if you have any questions & thanks in advance for your help here!
