- Aug 7, 2023
- 56
- Vinyl
- CircuPool RJ-60 Plus
But then when refilling? Fill halfway with water first? and then start pouring in the sand?
Fill with water to just above the laterals. That way you're sure the sand will flow under them without leaving a void. Or, follow Hayward's instructions from their manual:I think I know what I'm doing as far as getting the old sand out. I plan to use a "shop vac" to vaccum out old sand. But then when refilling? Fill halfway with water first? and then start pouring in the sand?
I removed 200# of sand from mine in short order with a shop vac. It takes a few dumps but It’s definitely better than scooping.Shop vac to remove the sand? You might be there till next swim season opener. Use a piece of tupperware or rigid plastic cup to scoop and dump it in your wheelbarrow.
I have a Dreamline filter. 175 lb of sand. I’m guessing it’s a 19”??No, fill directly with dry sand to the level specified in the sand filter manual.
Use the correct sand as described in Sand Filter Use and Care - Further Reading
What model sand filter are we discussing?
We recommend you just use old fashioned pool sand for best results. It has stood the test of time.Has anyone ever mixed Zeolite with HTH pool filter sand?
Just use sand, you'll be happier.Has anyone ever mixed Zeolite with HTH pool filter sand?
For information purposes. Can you tell me what the headaches are with zeo?Stick with sand- you can always add a little de after backwashing to help with the finer particles without the headache that often accompanies zeo.
It is lighter than sand so it can get “blown” back into the pool with a higher rpm pump. With a single speed pump you have no control over this. It either happens or it doesn’t. This happened to me. I got a poof of gunk in my beautiful pool every time my pump came on.For information purposes. Can you tell me what the headaches are with zeo?
Thank you for the info. Considering I have a single speed pump, I would agree that Zeo is not for me.It is lighter than sand so it can get “blown” back into the pool with a higher rpm pump. With a single speed pump you have no control over this. It either happens or it doesn’t. This happened to me. I got a poof of gunk in my beautiful pool every time my pump came on.
In my experience it also gets clogged eventually & doesn’t backwash well after a time. It’s possible that it can be deep cleaned but I never attempted it & just replaced it with regular pool filter sand.
Mine started out white & fluffy but after 2.5 seasons it looked like used kitty litter. I never had a swamp or anything in that time.
People who have the ability to filter low & slow (vsp @ low rpms) and also who never have an algae issue don’t have as many issues with it.
It’s also more expensive depending on where you get it which may or may not matter to you.
It came with my pool and the installers refused to put regular sand. They also put mason sand directly in my step weight ballast and said it would be plenty to hold them down (not true) and that it wouldn’t grow algae (also not true).
The lower micron filtration that it is supposed to provide can be achieved with a little de so the other things aren’t worth the hassle in my opinion.
YMMV.
For someone with a vsp that can tweak operation it may be worth rolling the dice & may be no trouble at all. It’s also nice that it weighs less but that should really be a one time event if you don’t use stuff that messes the sand up. I suspect it’s weight is why many service techs like it.Thank you for the info. Considering I have a single speed pump, I would agree that Zeo is not for me.
