- Jul 15, 2010
- 10
so one of those pumps would make my pool floor BETTER... like I would not have to vacuum it at all? And they are interchangeable? (with my intex 16 X 48 pool)
foster400 said:@ heather
you may have to vacuum sometimes but for sure not near as often. I cant remember does the 16' pool have 1.5" hoses, if so you just swap the pumps out.
@cna
Ive read that you would be better off using treated wood blocks. Some have mentioned that the pavers will crack.
cna91 said:Thanks for the advice on the lumber, but I already have blocks, and I only have another month or 2 for the season here in northern Utah and plan on pouring a concrete pad for it next year. Do ya think I will be okay using the blocks for this year?
@jsf...you are saying that the tops of the blocks/wood need to be level with the top of the dirt? Does this hold true if I also have the linersitting on the 1 1/2" foam boards? Thanks again. Sorry...total New B here.
cna91 said:New Intex owner here. Got the 24' round. Crew coming out to level yard tomorrow. I have some of those cheap 12X12 inch pavers to put under the legs. Without going out there, I am going to guess that they are about 1 1/2" thick. My question is, do I need to get them to ground level, or can I just leave them on top of the leveled ground. I am also planning on putting the liner on top of the blue or pink foam. Thanks.
mcdonl said:Hi there. I am new here, first post. I am in Maine and just put up a 15x48 Intex Metal Frame pool...
PS - How long does it take a 40" deep, 15 foor round pool with approx 4400 gallons of water to be warm enough to swim in?
crispycruiser said:HELP! Any advise for nutgrass (nutsedge ) that grew through the liner on my 16" round intex liner. I thought i did everything I should have. I first had the landscaper remove the sod in a 18" round circle,then I leveled the ground, had 2 yards of sand delivered, wheel barreled it from the driveway to the back yard, leveled that, set pavers under the supports, coverd the pavers with thin rubber so the liner can't come into contact with the liner,put down the tarp that came with it, bought a armour shield pad from a pool contractor and put that down over everything. I then added a saltwater chlorine generator, filled the pool, was in absolute awe of my fine job, I did it all myself, (51 year old grandma!!) I lost about an inch and a half of water in 1 week and thought that was too much for evaporation. Everything was great,after 1 week my hubby and I were floating in the pool when i got on a pair of goggles to check out a spot on the floor of the liner and i was shocked to see grass growing through the liner. That's why i was losing a bit of water. I emptied the pool , got a new liner, I put down IMAGE nutsedge killer down a few days ago, and am afraid to put the pool back up, Any ideas on something that nutgrass can't grow through? Thinking about putting down a concrete pad, but I don't know how much that would cost, or is that a crazy idea?? Hoping that the nutgrass killer works..[/quot
wow, sounds like you did everything right. i sprayed the area with roundup repeatdly and put down some liner shield before i put the ground tarp down and havent had any problems so far. i was also thinking about a concrete pad for next year as that would ensure a level weed free base.
I am afraid this got lost in the discussion of the board...any thoughts?cna91 said:I wish this site had a "search this thread" function. Anyways, I know it is a little early to be talking about this, but I live in northern Utah. What are the thoughts about leaving up my pool during the colder time of the year. Trying not to say the "W" word yet. Obviously if I did, I would drain it to below the level of the return. and take the pump inside. Thanks again for your time.
cna91 said:I am afraid this got lost in the discussion of the board...any thoughts?cna91 said:I wish this site had a "search this thread" function. Anyways, I know it is a little early to be talking about this, but I live in northern Utah. What are the thoughts about leaving up my pool during the colder time of the year. Trying not to say the "W" word yet. Obviously if I did, I would drain it to below the level of the return. and take the pump inside. Thanks again for your time.
cna91 said:I wish this site had a "search this thread" function...
