Hello pros. First post.
Quick run down:
I said screw it and went and put 3x 40lbs salt into the water. I'm not 100% sure how long it takes for the panel to update the salt level but after over an hour it now show 2500. The green light for generating chlorine is on as well as super chlorine since I flipped the switch to super. The red "check salt" light is still on so I doubt it's actually generating chlorine.
Do you pros think the cell's salt detection meter is dead in the water? (1st of many puns). How long does the T3 cell and panel take to report accurate salt readings?
Any tip is much appreciated
Quick run down:
- Pool is small 9000 gal
- Heated
- Salt
- Hayward T-3 cell
- Hayward Aquarite panel
- Age unknown
