I think I found a bug in the RS4. My pool pump runs 24/7 at 600 rpm. I have a waterfall and Hotspot FPH system. I have the waterfall turn on at noon and turn off at 6pm, this bumps the pump up to 2000 rpm. The FPH system is connected to the solar heat input of the RS4. When triggered it bumps the pump up to 2500 rpm. Here's the bug, during the day (noon-6pm), when the FPH system turns off, the pump is supposed to fall back to the next highest accessory, which would be the waterfall at 2000 rpm. This does not happen. It reverts to the pool default - 600 rpm. So, during the day when my waterfall is running my FPH system will kick in and then after a while when it shuts off, my waterfall shuts off as well due to lack of flow.
note: The FPH system is a heat reclaimer that takes the waste heat produced by my home AC system and puts it into the pool. So, it can turn on anytime - day or night.
I have called Jandy and they told me to wipe the PDA and reprogram everything, which I have done.
Anyone else experience anything like this? Perhaps I have an older version. Can anyone confirm their system works correctly with the solar option enabled?
