Hello,
I recently purchased a home with a pool. Previously I had zero experience working with pools. We tried opening the pool ourselves and ended up with algae. Water was green and cloudy with noticeable algae floating on surface.
Couple weeks later, water is now crystal clear but we have brown spots scattered throughout the floor of the pool. When brushing it off it returns (not sure about if it returns to exact spot or not). And when vacuuming it to waste there seems to be an improvement but also seems to return in some places. Or I could just be missing spots. Sometimes they are so small that it is easy to miss at first glance.
After looking at stuff online it kind of sounds like yellow algae due to:
-Brushing causes it to poof up in a cloud
-It returns
But then these aren't happening:
-Doesn't appear to be on walls
-It is all over the pool not just in the more shady areas
-Water chemistry seems to be mostly fine and it is clear. We had high alkalinity that we got down and now pH is a smidge low.
-We are in the midwest and sounds like it is less common outside of the south.
I've tried touching it and seeing what it feels but it was just too hard to tell with 100% certainty because I have to go underwater (since it isn't on walls) and it immediately blows away when touched. There was one spot that maybe felt slimy but I think it felt gritty in other places.
I've tried asking a couple different pool stores about it and neither seemed concerned about it. Just mentioned vacuuming it out. If it is dirt/something that can be vacuumed out does it normally more than one go around?
We don't have a test kit yet but have been utilizing the pool store down the road. I understand that isn't ideal but here's the latest results from them:
FC: 3.86
TC: 3.97
CC: .1
pH: 7.1
Hardness: 197
Alkalinity: 146
CYA: 35
Copper: .3
Iron: .1
Phosphate: 1298
I'll attach some pictures. It is hard to pickup in photos but I'll post one and then another of same spot zoomed in. Would appreciate any suggestions on what it could be.
-It returns
FC: 3.86
TC: 3.97
CC: .1
pH: 7.1
Hardness: 197
Alkalinity: 146
CYA: 35
Copper: .3
Iron: .1
Phosphate: 1298
