So I bought 20 mule team boraxo put it in a bucket of hot water, it didn’t dissolve, what am I missing
Moved from here
Moved from here
Just wondering, how did you get your boraxo to dissolve?Well... I added a gallon of LC and a 4 lb box of 20 mule borax before going out to buy the stabilizer. Thanks for the warning--it would have been a shame to get an algae bloom right after the purification.
Added 4 lb of stabilizer about an hour ago in a skimmer sock and it's almost entirely dissolved. (I used Chlorox brand.) I'll try measuring CYA tomorrow afternoon and then again in a couple of days. Between the stabilizer and the pucks should get CYA to around 30 ppm. Hoping that's high enough that my chlorine doesn't burn off too fast in the 100 degree weather. I need to leave the pool for a few days next week so, conveniently, I plan to leave a dispenser with some trichlor tabs and FC high. Now that my CYA is down, any thoughts on the maximum FC level that we should be swimming in? I would still like to keep FC on the high side while the weather is hot, to ensure the algae doesn't come back.
Below are latest test results with my Taylor kit:
FC 7.5
pH 7.2
TA 60
Did you buy BORAXO (which is a detergent) or 20 mule team BORAX?boraxo
What are you hoping to achieve by adding Borax?
