Anyone know how to kill these tiny black flea-like pest that are investing my pool? From what I gather on Google, they might be springtails, but I am not sure. They seem to cluster and float on the surface of the pool and they hop around. They reproduce, astonishingly fast. I live in San Diego, CA. I think they first infested my pool after installing new sod in the backyard 4 months ago. I was watering every day for a few week, and noticed them in my pool. No matter how hard I try to get rid of them, they keep coming back. There are millions of them in my pool. I’ve tried everything. I net with a fine mesh net every day which collects most of them, although some get through because they are that small. Then, I put the net in a 30 gallon barrel and spray them with white vinegar, which seems to kill them on direct contact, and then I rinse them off into the barrel. I do this every single day, and when my pool shuts off around 4 PM thousands more start clustering around the corners mostly and along the sides. I tried adding 2 gallons of chlorine per week, then 4 gallons, and the chlorine did not phase them. I tried adding 6 gallons of white vinegar to the pool and that didn’t work. I tried chlorine and yellow H, and we phosphate shock the pool every week or two, and that doesn’t work. Phosphate level is zero so there’s nothing they can feed on. I’ve tried adding 20 to 30 ounces of dish soap to sink them, and they are back a day or 2 later. No matter what I do, they keep coming back. If I wait two or three days without netting them, there are tens of thousands of them clustering around the pool. I am not sure how they keep coming back. We have been getting intermittent rain, but they do not seem to be following the rain cycle. Does anyone know how to get rid of them for good? Temperature has been 50 to 65° and they seem to like the cold water. I wish it was hotter and I could heat my pool to 100° without costing a fortune to see if I can kill them that way. None of the chemicals in the pool phase them. They only die when in direct contact with white vinegar. Somehow they form a barrier and float on the surface of the pool and are impervious to the pool conditions. They are an extreme nuisance.
