I will have to get back to you on those photos!Remove the front panel on the heater and open a bypass valve to see if you can see water leaking.
Also show pictures inside the heater.
I would get rid of the tab feeder.
What are all of the chemistry readings?
Well that’s fun! Haha who needs a heater anyways! I’ll check this after dinnerIs the heater under a deck?
It is not safe to have a heater below a deck, so if it is, it needs to be moved.
The heater is probably destroyed anyway.
You need an iron cobalt remover. We would try that first and worst case scenario, drain pool and acid wash it.Hey everyone! Wanted to reach out for some advice/ comments on my current process. I am a new pool owner 3 weeks in! Pool was stagnant for a few months prior to moving in (a lot of issues with closing but they cancelled all their maintenance services at original date). We moved in with a swamp in the back yard.
After using the pool stores advice for 2 weeks, I decided to reach out online. I got tons of helpful advice but everyone directs me to TFP so I finally decided to try here for a progress review/advice.
I have a 35,000 gal gunite chlorine pool with sand filter. It’s currently sitting at 10.5 FC, .5 CC, and 0 CYA (using k-2006). I’ve been running pump 24/7, and back flushing filter every morning. There is a pretty bad black algae invasion that I just started scrubbing with a stainless brush (against the pool stores opinion). One day after it’s definitely cleared up some, maybe 5-10%, primarily on the walls as the floor seems more difficult to scrub. I am trying to maintain 12 FC just to kill the algae but I am not sure if that’s the right thing to do. Any guidance is greatly appreciated! Also is it safe for me to swim in to scrub the floors better? Thank you all!
What chemical is this product?You need an iron cobalt remover.
Thank you for following up with his recommendation! I am still waiting on my stain kit! Expecting it to come in Wednesday. Stains are not getting worse.What chemical is this product?
Why do you recommend it for this application?
Sodium Erythorbate or Erythorbic acid is a stereoisomer of ascorbic acid (Vitamin C).You need an iron cobalt remover. We would try that first and worst case scenario, drain pool and acid wash it.
I have been maintaining a slam, one of the parameters is 1-3 ppm fc… and I’m sitting at 10. Do I need to lower my fc prior to testing? Everything else within parameters.I think that it is probably copper.
Try the stain ID kit.
The heater is probably a total loss, but you can have it checked out if you want.
It doesn’t really scrape off or rub off.
If it was black algae, then you should be able to scrape some off like scraping off black mold.
Are you sure that you cannot scrape any off at all?Yeah it definitely does not scrape off.
Waxy might be black algae.It has a waxy texture to it prior to brushing.
