My bad....Copper SulfateCalcium sulfate or copper sulfate?
What do they think the black is?
If it's copper stains, adding more copper will just make it worse.My bad....Copper Sulfate
Can you post a closeup picture of the black stains?
attached are the updated picture and latest test of water done today. When I opened the filters one week back it was showing green color all on filters.Your signature says salt pool, but I do not see a salt system.
Do you have current pictures of the system?
I see a tab feeder, which can cause some really bad chemistry if you are not managing it continuously.
What is the worst that the chemistry ever got?
What are the current chemistry readings?
Pull the filter cartridges and look for turquoise and/or black colors, which would be good evidence of copper.
You can also drain and sand the entire surface to try to remove the copper stains.
Maybe try the Jack’s first and then be prepared to acid wash and/or do a thorough sanding using diamond sanding discs on power sanders.
Get local professional advice before deciding what to do.
If the green was blue/green or turquoise, then that certainly sounds like copper.When I opened the filters one week back it was showing green color all on filters.
Black marked piece is the ionizer, it turns on when pump is on and turn off when pump off. Currently I turned off. Blue marked one is the scale blaster.
I contacted Jacks' they are sending test kit to me to test. Thank you for taking time to look at the info and making suggestions.Ok, it looks like the system also has silver ions, which can also create bad metal stains like brown etc.
I would see what Jack's recommends and maybe try their #2 copper and scale stuff and then maybe have diamond sanding equipment ready to sand and polish everything when the pool is drained to get rid of anything that the # 2 copper and scale stuff does not remove.
Take all necessary precautions and do your research to understand all costs, risks and potential benefits.
I recommend that you consult with a local professional expert to help you decide what to do and to create a plan that is safe and effective.
