Polyfill può essere utilizzato negli skimmer nelle piscine skimmer? Vivo in Italia dove posso trovare il polyfill?
inserting this material in the skimmers should it absorb the oxidized iron? should it change color once the iron is absorbed?I see you posted in the polyfill thread- its quite old so I’ll answer your question here.
Polyfill is what is used to stuff cheap pillows & stuffed animals.
It’s in the craft section at most stores.
In the US its about $5 a bag. Or you can recycle some from an old pillowView attachment 519409View attachment 519410View attachment 519411
I can also put it in the pump prefilterI see you posted in the polyfill thread- its quite old so I’ll answer your question here.
Yes - you can put it in the skimmers.
today I added 6kg of sodium bicarbonate but the ph didn't rise, why do you think?If the water is changing color when chlorine is added try the polyfill method to remove as much iron as possible before adding any more sequestrant - afterwards deal with the stains using the aa treatment & sequestrant.
The sequestrant can only do so much if your iron level is very high.
If you’ve got iron in your fill water, use Polyfill to remove it
EDIT: Found out this method only works if your iron is oxidized already, meaning it’s got a dull or bright green tint to the water, or a nasty brown tint. If you know you have iron in your fill water, but it isn’t oxidized yet, bring your pool to shock level and it’ll turn the telltale green...www.troublefreepool.com
Because your ta is incredibly low?today I added 6kg of sodium bicarbonate but the ph didn't rise, why do you think?
The purpose is to Capture visible ironFollowing...how does this compare to skimmer socks? I happen to have a pack on hand.
Those are filter balls they go in your filter in place of sand. We don’t recommend using anything but sand in a sand filter.
yes I know they are filter balls for filters but I didn't think of putting them in the filter but in the skimmerThose are filter balls they go in your filter in place of sand. We don’t recommend using anything but sand in a sand filter.
This is what you need. You just put some in the skimmer
RAYHER HOBBY, Imbottitura In Poliestere, Molto Soffice, Fiocchi, Bianco, Sacchetto 500 G, 40 x 30 x 23 cm, 517.1 grammi https://amzn.eu/d/j27mhFh
They are very expensive & i am not sure exactly what they are made of or how many might actually fit in your skimmer.yes I know they are filter balls for filters but I didn't think of putting them in the filter but in the skimmer
Ho comprato questo che mi avete consigliato e ne metto un po' in ogni skimmer (ne ho 5 in tutto) ora il materiale dovrebbe cambiare colore se assorbe il ferro o no?si lo so che sono palline filtranti per filtri ma non pensavo di metterle nel filtro ma nello schiumatoio
Translation:Ho comprato questo che mi avete consigliato e ne metto un po' in ogni skimmer (ne ho 5 in tutto) ora il materiale dovrebbe cambiare colore se assorbe il ferro o no?
Lo indosso da due giorni ma finora non ha cambiato coloreTraduzione:
“Ho comprato questo che mi hai consigliato e ne metto un po' in ogni skimmer (ne ho 5 in tutto) ora il materiale dovrebbe cambiare colore se assorbe il ferro o no?”
Rispondere:
Dovrebbe diventare marrone se assorbe il ferro - quando si sporca puoi rimuoverlo con cura e sciacquarlo (fuori dalla piscina da qualche parte) e poi rimetterlo nello skimmer per raccogliere più ferro
Is the water a color instead of clear when chlorine is added?Lo indosso da due giorni ma finora non ha cambiato colore
