Im needing to fix/update some plumbing and was going to go with flex PVC for the above ground stuff. Where is the best place to get 2" flex pvc? Should i get sched 40 or 80?
For the most part yes. I am retro fitting an existing system at the house i just bought and converting the pressure non-booster line to a vacuum line. There is also an existing HVAC system that sits close which it preventing me from re-pluming the whole system. So for now I thought i best to run with flex. Im only going to be using about 6' which will be used on the new vacuum line and the existing main/skimmer line which is already flex from the 3-way valve to the pump.
