- Jun 24, 2021
- 7,507
- Vinyl
- CircuPool RJ-60
What testing kit would you recommend?This is typical in failure analysis. Your past experience is causing a bias in your assessment of problem. Step back, think about it. You had a piece of rebar replaced and a patch. You have a device to read chemical levels. Which is really subject to causing water to not change calcium levels? Pools are built every day, new rebar, new plaster, none ever resist CH changes at start up. If anything did result from the new start up after repair, acid wash, etc.... it went to affecting the meters, not the pool, in my book. First stop for me is see what a good test kit says about all this.
What testing kit do you use and recommend?I’ve been down that path, it can cause even more confusion. I persisted with a ColourQ for a while but when it can time for new reagents and cuvettes I swapped over to a Taylor kit with a speedstir. Initially it seemed like a vast improvement, it couldn’t read FC above 10ppm but I overlooked that since I no longer had to self asses colormetric test results. I realised very early that I must handle the cuvettes very carefully to attain constant results. It seamed to work for a while but I eventually found myself trying to match inconsistent results. LaMott offered to test and recalibrate the device with a package that included new new reagents and cuvettes. They confirmed that it tested total hardness and also suggested that the light source does degrade over time.
@AUSpool is in Australia...they don't have access to the same kits we do in the US.What testing kit do you use and recommend?
I don't see XL option. Where is this?The XL option is great for newbs who haven't become one with their pool yet, and also those with swamps. Both will be testing more often than normal and may blow through the supplies.
I don't see the XL option. Where is this?+1 on the XL option. The others are not necessary. I bought the pH meter and don't use it. More hassle than it is worth.
It is the SLAM option. Sorry for being imprecise...I don't see the XL option. Where is this?
The meter and SWG use conductivity to report salinity. Any metals in the water such as calcium and also the temperature will alter the conductivity and the reading.Your thoughts?
I use the Taylor K2006 with the speedstir and top it up with reagents from a local company. I believe the TF-100 is better value but we can’t get that in Australia. Similarly the K2006c is better value but when Ifactored in shipping and the need for top up reagents I decided to import the standard kit.What testing kit do you use and recommend?
Good choice on the TF-Pro.I think I made a decision. I'm going with the TF-Pro. I really don't need the salt version as the only difference that I can see is the salt testing reagents. I have a separate hand held salt meter and the Jandy Aqua Link shows a reading of salt as well. Your thoughts?
