- Sep 9, 2023
- 44
- Plaster
- Jandy Aquapure 1400
It sure does... Should it be hanging outside?
Eh, I'll just make the pb replace it. But surely that's not the root cause of my problems...It is made to be outside.
Maybe you can dry it out if you can get it open.
The system says "No Flow" so it is not going to turn on the SWG.But surely that's not the root cause of my problems...
Do I need to unscrew all those screws behind the breakers? Or is there a simple set screw and it swings out? I assume I need to shut power to the panel?The system says "No Flow" so it is not going to turn on the SWG.
Replace the Trisensor and then you should get a good flow and the SWG should work.
Show the circuit board if you want us to look at that.
Trying that now but struggling to disconnect the flow sensor. I don't want to break it. Does it just pull out?I would replace the sensor.
Here is a test you can do.
Disconnect the sensor plug and use the three buttons to do the three tests.
All 3 tests failedI would replace the sensor.
That is close enough.3.2
74
90
So just need a new module.That is close enough.
I would call it a pass.
The salinity was probably recalibrated, which will change the number.
The other two are ok if +/- 1.
got it...definitely wasn't hooked up. I'll just have the PB fix it when they replace the module. hopefully it won't take them forever.The red plug is the communication plug.
The other end should connect to one of the red plugs in the second picture or in the third picture.
There should be a plug from the red plug in the second picture to one of the plugs in the third picture.
The third picture is the multiplex board and it allow extra communications connections, but the board needs to be connected to the main board.
