I have any AquaLink RS4 Jandy that controls my spa. I have temp 1 set to 102 and the maintain temp feature set for all day so that if I have the heater on, I'd like it to get to the temp and stay there until I turn the heat off.
When I turn temp 1 on it heats to the desire temp and the temp 1 light goes green as I'd expect. However, then the filter light starts to blink going into what I believe is cool down mode and I get an message that filter may turn on to maintain temperature. The problem is that after around 5 minutes the filter goes off and stays off. Thus, even though temp 1 is still on, the heater says in enabled mode (green light) and never kicks back on when the temperature drops because the filter is off and so it won't fire up the heater.
Besides fixing the unit itself, my other though was to upgrade my system with a remote or Wifi enabled Aqualink device so I can just manually turn on the filter and restart the heat. I've had a two technicians say they recommend a AquaLink full system replacement when I only asked about adding the remote/wifi and didn't tell them about the issue above. They both recommended a full system replacement and it seems they're just trying to sell me a new system but maybe mine is too old to be upgraded with a remove/wifi. My aqualink is original to the spa that was built in 2008.
