- Aug 31, 2021
- 216
- Plaster
- Pureline Crystal Pure 60,000
Yet another pool owner frustrated by the skyrocketing cost of liquid chlorine and interested in reducing time spent lugging and dispensing LC. I won't ask "is a SWG worth it" because the consensus on this forum is obvious - rather, I have a few questions about specific SWG systems and integration with automation.
1) Any experience with the Calimar SWG systems? I'm eying the CMARSHA60-3Y (60k gallon) unit, which seems to be out of stock everywhere unfortunately. Should I wait for it to come back in stock (a couple of online retailers say anywhere from ~a week to a couple of months for this to happen), downsize to a ~40k gallon cell, or look at other brands/units? Are there any similarly-priced options available in a 60k gallon cell (most I've seen are much more $)? FWIW, I have a Calimar VS pump and am very pleased with the build quality and value, so I figured I'd start with this brand.
2) I have Jandy iAqualink automation but am not considering a Jandy SWG due to their anti-DIY business model. If I understand correctly, the SWG system should be powered off completely whenever the pump isn't running and/or when the pool/spa is in spa mode? If this is the case, I believe I can accomplish this by running 120v power to salt system through two Jandy relays in series:
3) Once the salt system is "dialed in", how frequently should I expect to need to operate the salt cell controls? I want to consider this when comparing accessibility between different control panel mounting locations.
4) In general, how does acid demand with a SWG compare with acid demand for a pool maintained by liquid chlorine? I use very little acid when running my pool on tablets, and "moderate" volumes of acid when running my pool exclusively on LC. Should I expect acid needs to increase substantially when switching from LC to a SWG?
TIA!
- "Filter pump" relay that currently controls the middle speed of my VS pump - whenever this relay is open, the pump isn't running.
- "Spare relay" configured via the DIP switches to switch on whenever the pool/spa is in "pool mode", and off whenever the pool/spa is in "spa mode".
TIA!
