Yours is one of the pics I showed my PB initially and I have it saved on my phone. [emoji5]. Thank you for posting it here!nice progress... yes have them re-do the inside... IMO those inside cuts do not look but that's just me, hope they change it up so you can be happy with it... I think I have a pic of mine on my build thread somewhere.
. I hadn't thought of doing something different like that. I'm having trouble visualizing it..If it were me I think the center of the table would look good with a random rubble mosaic to contrast the geometric exterior pattern.
. We showed them ap's and also one we found online done by Backyard Amenities. I'll be printing them out this morning.Love how they worked with you on the fire pit and made sure they understood what you wanted. You might be a trend sitter with that! That table top-nope. Print out and show them ap's! NICE! Kim:cat:
I know what a difference the caulk can make now so I'm not going to make an issue out of the outer circle. I saw him cleaning up those quite a bit to even up the cuts so I'm going to leave it be. Those pieces on the inside need to be the same size and shape though. Pretty sure he's using an angle grinder and doesn't have much patience. This is the same crew that took 6 days to do our tile & coping a couple of weeks ago.Doesn't ANYONE in the pool industry own a wet saw?? The reason none of these people can accomplish straight cuts and consistant joints is that they try to freehand everything with an angle grinder. It's like going into a butcher shop and all they have is hatchets. I realize that curves need to be freehanded, but you can tighten up those radius edges with the right wheel and a little patience. Grout, like caulk, makes every amatuer look like a professional, but you need joints to get grout into. On the table top in question, he just needs to trim a little here and there and smooth out some choppy radiuses and it'll all be golden.
Builder told me I needed to lay out my toe tiles today because the tile guys are going to put them in. I'm worried for a few reasons. I have an exact number of tiles since I'm using my samples, they are Light Streams, the pool is still a really gross mess and no clean up has started on the shell yet. PB said it would be fine and they would clean just enough for the pieces to be installed. He said when we get plastered the tile guys may not be available if I was wanting to wait to have them put in. [emoji28]. Most builds I've read here had the plaster company actually install them just before plaster but apparently that's not how they do it. I really feel like putting them in today is a mistake and the tile guy visibly rolled his eyes at me in front of the PB when he heard there was a specific order and that I needed to be the one to lay them out (three different colors). Thoughts?
