I opened the pool on Monday, water level was about 1/3 down. Known leak for several years.
FC: 0
CYA: 0
PH: 7.3
TA: 115
CC: 2.5
I read a bunch in TFP and was led to believe I had an ammonia problem. I followed the ammonia instructions of using liquid chlorine for bringing the FC to 10ppm and testing after 30 minutes. First test: 1 FC; Second test 2.5 FC; Third test 10 FC. I understand that I am supposed to SLAM, but will wait until morning. CC Test after 3rd addition was still 2.0.
Questions:
1. Since the 2nd addition of the 10ppm of liquid chlorine, I can now smell the chlorine near the water; I assume it is the combined chlorine. Why do I smell this now, and why didn't the CC decrease significantly with 5 gallons of chlorine??
2. In the morning, do I add the CYA (sock method) and immediately keep shocking? And should I figure that the CYA # already is what I am actually putting in, or should I still consider the CYA # as 0 for calculation purposes?
3. Will the SLAM cure the combine chlorine problem? Or is this a breakpoint chlorination problem that will require more work?
Thank you for your input.
FC: 0
CYA: 0
PH: 7.3
TA: 115
CC: 2.5
Questions:
