Hi There! First post as I’m somewhat baffled but always appreciate the info here at TFP forums so thought I give it a shot. I think I know the answer but wanted the experts to weigh in.
Recently my combined chlorine has gone from 0 to 3 and I’m not sure why. Water is clear, bright, no debris, algae or any other signs of concern. Not even a smell but it is an outdoor pool. My only conclusion is that there is a potential algae bloom I cannot see but I don’t believe this would create such a high CC. The weather here has turned from relatively mild to blistering hot in short order. Going from the 90’s to over 110. Filter is clean, pool is brushed, maintain chlorine levels in accordance with CYA level. Alkalinity is relatively low but the pool is less than 2 years old
I believe the solution is to SLAM and I have a Taylor FAS-DPD kit on the way. I’ve been adding liquid 12.5% and running the filter essentially non stop to aerate and and better oxidize and it seems to be coming down slightly, but it’s been 3 days now without much change.
Should I continue on as is or SLAM over the weekend? Water balance below
Taylor K2005
PH 7.6
FC 8
CC 3
CYA 50
TA 70
CH 300
Taylor K2005
PH 7.6
FC 8
CC 3
CYA 50
TA 70
CH 300
