Hey all. Just wanted to run this through really quick make sure my process is right. So, I was at 12ppm chlorine at 6pm. Added 100 Oz and expected chl to go up to at least 16ppm (usually. 16 to 20 Oz raises chl by 1ppm). I waited about 45 mins and tested chl. I was shocked, no pun, that result waS only 14ppm; only went up by 2ppm?? So, added another 100 Oz and this time I tested only about 5 mins after adding and brushing. This time it was at 19.5, maybe 20ppm, going up by 6ppm this time?? I guess chl level starts going down almost instantly after adding? Feedback, experience, comments? BTW, I'm having bit of algae trying to bloom is why doing all this.
Also, did the combined chl test and sample did not turn pink..as I recall, it never does everything I tested it which is why I stopped buying it. Could it be that when chl is so high that that test is null?
