BIG thanks to everyone that has posted on installation of Pentair Easytouch systems. It would have been tough without you guys/gals. I consulted numerous posts on TFP to ensure I wired up things correctly. (Or at least reasonably as there are numerous opinions on 'correct').
I had mounted this last year to the side of the house but had not rewired power to the panel and such as I knew it was going to take a while.
Spent all day yesterday digging a hole as close as I could get to side walk where I cut through the old conduit and old wires. I pulled these into the new control panel and wired it all up yesterday.
Took from before noon until 6:00. Luckily I'm not charging by the hour. It took a couple of trips to OSH to pickup extra wire, flexible conduit and such.
I still have to wire in the temperature sensors and valve actuators, but the chlorine generator is online.
Then I have to figure out how to program the Pentair Easytouch 8. (Yeah, 8 circuits is way overkill, but I didn't want to have to upgrade for more circuits later). The VS Pentair pump is currently just running it's program to heat the pool from the solar panels.
Details from the top breaker down:
15 Amp 120v - powers panel
15 Amp 120v - power for GFI plug on side of unit
15 Amp GFI 120v - Pool light = Aux1, Spa Light = Aux 2, 120v AC Plug = Aux 6
15 Amp GFI 120v - reserved for lights on trellis
15 Amp GFI 240v - Pump + SWG
