- Mar 22, 2021
- 60
- Vinyl
- Pentair Intellichlor IC-60
So finally almost have the pool balanced..I have been adding chemicals slowly to make sure I don't over do anything...Here are my latest readings:
Free Chlorine: 6.6
Total Combined Chlorine: 0
PH: 7.2
T/A : 60
CYA: 45 (adding slowly, I know this is low)
Salt: 3600
Water Temp: 80
It's a Vinyl Liner so I haven't worried about Calcium Harndess
Getting pretty close I think! As I bring the CYA up to about 70 slowly...THoughts on PH? That's the one that's kinda out of range for me I think... Anything to use or do for that with out affecting the other stuff? I thkn Free Chlorine is high too, so I lowere my salt cell (IC60) for my 33kGallon pool to 16% and have been trying to keep the auto cover open to burn off some of that chlorine. I think it gets high, because I tend to keep the cover closed when not using the pool...But I may need to change that game plan so Chlorine doesn't build up.
Thanks in advance!!
Free Chlorine: 6.6
PH: 7.2
T/A : 60
Salt: 3600
Water Temp: 80
Thanks in advance!!
