DaninFLA
0
what is your TA reading? pH rises from the alkalinity in the water and aeration. your pump has been running a lot so lots of aeration which raises pH. that's why we push our pH low before the SLAM. cant test your pH if your FC is over 10. even if it has fallen for some reason, you want to keep it in range. so if it fell lower than 7.2 you need to raise it. especially with people swimming in the pool. don't want too high/low pH.
for the water clarity, it will take some time with the sand filter and babysitting with DE but you will get there.
