I do not have a sand filter, but from reading on here the DE can really clog up fast. that's a good thing, its really good at doing what its supposed to do. It will clog faster at first and less over time. for dirtier pools during SLAM, I have read on here it can be as quick as 30 minutes! that's my kimkats recommended you do it when you are home.
and the ring that hold the light capsule can be replaced...but it sounds like the pool guy probably cut the line?? where is the line now?
Sounds like it should be OK to do one "DE cycle" as I mentioned above then... put in after work, monitor and backwash before bed (if not before) just to get started...
When I pull a water sample, the color of the water is clear as can be, but I can actually see the little particles floating around in there... would love to filter those out and see what i'm working with!
Well claimed a previous owner replaced the fixture with some smaller fixture that's back in the setting (can't see it from the surface), so wires should be connected to that. The pool vessel doesn't leak so something is plugging the hole.
Apparently the story goes that a doctor bought our house in the early 2000's and then took a job about 3hrs away in 2010 or so... but our house didn't sell... eventually he let the house go to foreclosure in 2013, at which point a "flipper" bought it and did lots of cosmetic upgrades, but clearly didn't put any real $ into the pool. Then we bought it in November 2014...
So nobody that's actually cared about having a pool has monitored it since ~2010/2011. And it appears the Dr. didn't have the stomach to do things right when he did them.
Talking to some of our neighbors it was apparently common knowledge that the pool leaked, and that this light was missing. The only pre-existing leak I fixed in about 20 min with some "pool putty", but apparently that was a known thing for years. But then the PO probably didn't want to learn it himself (lots of people don't I'm sure) and the "pool guy" said the only solution was to replace skimmers and repour concrete.
Still I'm looking at $70k? pool/patio installation that's so far required all of $30 or so in maintenance (excluding chemicals) and some basic research, and we got a very good price on the house regardless of whether a pool was attached... with a "growing family" I think it will be very nice, it's just frustrating trying to figure out what wasn't done right in the past and trying to resolve it..
