I have a 3yrold hottub that came with the house I bought in April 2021. I decided to start fresh as I saw things floating and the filters were really dirty. I bought new filters, treated with ahh spa pipe cleaner to make sure the pipes were clear & clean, drained and refilled. Then my problems really began. It seemed like pieces of white formed slimy pieces were everywhere! (The residue from pipes?) It wasn't white mold, these were like little white flat, formed stick pieces. That evening, my tub began leaking. I treated it with a pipe seal you put in the water. The leaking stopped. I came down with covid and for nearly 3 months it was not used or touched. My daughter came in, turned the heat as low as possible and thinking it was not being used, may as well shut off to save electricity during cold weather. For nearly 3 months, no circulation. I recovered from Covid, went to check on things, it was quite the mess. White mold everywhere. I see here you guys using the pipe cleaner that led to my leak. Any suggestions other than using something that will break my pipe seal?
-Hottub headaches in Indiana
