Marla..... I have so much to congratulate you for!!!!! Aubrey is beautiful! A sweet bundle from Heaven! Seeing her picture gave me chills.
And your pool!!!! Oh my..... a piece of Heaven for sure!!!! I love the Blue Smurf pebble color. It's a wonderful blue! I am thrilled for you on both counts - baby and pool!
You may not need more input on maintaining your pool, but here goes. I can't give technical help with levels outside of the standards on TFP, but I know there is some haggle room with different combinations (that's what I still haven't got a good handle on). That's awesome your PB's service will do it the TFP way and for 2 months! My pool guy more or less handed the reigns over to me pretty quickly when he saw my record keeping chart of chem levels. I don't believe he intended to come out more than once a week, either. He still came out weekly for the first month, but I think just to check my FC levels as a backup. Also, he did insist on using pucks for the first month until we switched over to the SWG system. I guess that was for warranty purposes. Even with pucks, I was still adding lots of bleach to keep FC up - that was the end of July through August, hot and lots of sunshine. Once the SWG system was switched on, I don't believe I added anymore bleach until winter.
Because my pool guy was using pucks, he wanted the pump running 24/7. I think I remember someone on here just removed their pucks as soon as their pool guy left. But this is where I was like a deer in the headlights - I didn't even know where the pucks were added, so I couldn't remove them!! Lol!!!! I know, hard to believe, right? But all those pipes and everything at the equipment pad totally overwhelmed me. Now it all seems pretty easy! And I'm still learning.
My pool guy also set the water features to come on about 10 minutes each day - to keep things moving and avoid algae growth in the basket on the equipment pad (mine gets lots of sun).
As far as your pH level..... I don't believe your pH level will lower just because you shut off the water features; that will just slow down the pH rising. (PLEASE TFP experts correct me if I'm wrong!) For my pool, the pH always wants to rise - I believe due to the new plaster. It's still a challenge to keep the pH where it should be. I've read on TFP that a SWG system raises the pH somewhat. (not affecting you until your SWG is turned on) For sure, running your water features a lot will raise the pH even more. But I think the pH will be rising anyway without the water features running with the new plaster.
Once the puck month was over, I ran my pumps in the daytime. There's a lot of variables in that decision, such as - if your electric plan is cheaper at night, then I might do that; I believe the aeration may help cool the water some if run at night when trying to keep the water cool; I preferred daytime running because I like the pump on when I'm swimming (too many floaties on the water's surface for my liking without water movement). That's all I can think of right now for reasons pro and con when to run pumps.
I was playing with the pump run time quite a bit in the beginning to get the SWG system leveling out the FC. I ended up with a schedule of about 4 hours in the morning and 4 hours in later afternoon to early evening. If I wanted to swim when the pump wasn't scheduled, I just turned it on for me. But pretty much, I set the schedule to fit when I liked to swim the most.
A suggestion I got from my pool guy (which may not be necessary, but now it's stuck in my head, so I still do it), is to run my pump at different speeds. I have a 2-speed pump, not your VS, so I can't tell you how it would work on your VS. The first 30 minutes and last 30 minutes of the day the pump is on, I run it on high. My pool guy said that would do a better job filtering debris - start the day and end the day with a good 'sweep' of the pump filtering. If I had more debris, I might add another 30 minute session. With your VS pump, you might have a more in-the-middle speed that meets a good balance of filtering debris and cost efficiency.
Lastly, as far as using pool math.... I really got the hang of it when Kim talked me through it one time by phone. That made it click for me. Again, now it seems so easy, I shake my head at my confusion back then. But at the time, there was just so much to process, that I couldn't do it all at once. Thank goodness for TFP, Kim, Patrick, and everyone else!!! Feel free to call me if you have questions about Pool Math. Send me a PM if you'd like my number. I'll answer what I know, and send you back to TFP on what I don't know!!!
Do you use the PDA AquaLink or use your phone? I use the PDA. If ours are similar, I may be able to help with the programming if you need any.
Congrats - all your vicarious living on TFP more than paid off!!!!!
Suz
One more thing. Do you have a record log you like for recording your chem levels and what you add? If not, I'll be happy to share the one I adapted from 'Flotsam' s log he posted on his thread on TFP 5-3-11.
Take care!
