Thread: Re: Need to close but have major algae. Clear it up first?
    Jul 2015
    miami florida
    1
    Help, have a pool that looks like pea soup and ​ dont know what to do????
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    If you clear it before you close it will make opening easier. To clear it follow the SLAM - Shock Level And Maintain process.
    Sep 2013
    Connecticut
    728
    Do you have to close the pool by a certain date?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Orlando, FL
    690
    SLAM. By close, do you mean a sale?
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Sep 2013
    Connecticut
    728
    Never mind; would delete post if I knew how.
