Results 1 to 9 of 9
Thread: Home Depot HDX Germicidal Bleach
    May 2015
    New Milford, New Jersey
    68
    Hi Everyone,
    I just want to confirm that others have successfully used this bleach for the pool, I got a pretty good price on it, thanks for your help!
    17x34 and ranges in depth from 3 ft to 6 ft.; I think 20-22 thousand Gallons
    IG -Vinyl with Waterfall
    Hayward Super Pump 1.5 HP
    Pentair DE 60 Filter
    Hayward H300 Heater; Taylor K-2006 Complete
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Home Depot HDX Germicidal Bleach
    Ive' used some it to add to the pool while waiting for a late opening and had no issue with a algae attack.
    But the MSDS stated % is "Sodium Hypochlorite 6% - 9%" so what % do you use in your calculations?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Mar 2007
    San Rafael, CA USA
    12,082
    It's intended to compete with Clorox brand concentrated bleach that is 8.25% so you should assume it is similar. The MSDS often gives a range because it relates to safety and not a guarantee of product concentration.
    From the Home Depot website this link to this MSDS that shows 8.25% as the intent though the ingredients range does say 6% - 9% in case the product degrades or is newer in manufacture so is higher. Again, assume 8.25% unless the product is older. This table will tell you roughly how quickly 12.5% chlorinating liquid and 8.25% bleach decomposes over time as a function of temperature.
    Atwork's Avatar
    Jul 2015
    Marietta/ GA
    7
    the germicidal bleach from home depot is what I am using. I compared the cost in the outdoor bleach (5%) $1 per jug than the germicidal (8.25%). Home depot is hoping you buy the outdoor, more expensive and not as powerful because it says outdoor.
    33K Gal Plaster Kidney bean shaped Pool, 2 HP Pentair Superflo, Hayward 244S Sand Filter. Pool built in 1984.
    Taylor K2006 Testing
    Marietta, GA
    I've been using the HDX in my liquidator for over 2 years and the only problem I have is the shelves at Home Depot are frequently empty, so I think other pool owners are catching on.
    Jun 2014
    Long Island, NY
    340
    Adam,
    Ypu may want to look into Ocean State Job Lot Store
    OSJL has a store in Sparta which should be close to you & the 12.5 % is still $2.99 Gal
    Looks like there is one in New City which could be close as well?
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by Atwork View Post
    Just make sure that you NEVER use "outdoor" bleach because "outdoor" and "splash-less" bleaches contain thickeners that cause foaming when used in pools.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,607
    AND check the date codes!
    There was a member that bought $80 worth of "water" as the bleach was so old it was useless. They did give her money back when she brought back all of the jugs and receipt to show them how old it was.
    Kim
    Atwork's Avatar
    Jul 2015
    Marietta/ GA
    7
    the germicidal bleach from home depot is what I am using. I compared the cost in the outdoor bleach (5%) $1 per jug more than the germicidal (8.25%). Home depot is hoping you buy the outdoor, more expensive and not as powerful because it says outdoor.
    Marietta, GA
