Results 1 to 14 of 14
Thread: Hayward SP1091WM with intex pool
    May 2012
    Las Vegas, NV
    92
    Has anyone had any experience with the Hayward SP1091WM and intex pool. This is the wide model.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Jun 2014
    15,130
    Re: Hayward SP1091WM with intex pool
    Hello! I see you haven't received a reply yet on your post about the Hayward SP1091WM. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    I assume you want to use the wide model to keep from losing too much depth? I went with the Dyna-Skim because I was afraid the wide model would deform the vinyl side too much. But yours is 22' vs my 16', so I don't think you'd have any problem with it. I'm pretty sure I've seen someone post here about using the WM with a pool smaller than yours successfully. Good luck. It's a nice upgrade.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    May 2014
    LA, USA
    16
    I installed the wide mouth in our 16' x 32' Intex and it works great.
    Trouble Free Pool
    AG-Intex Ultra Frame 32 ft x 16 ft x 52 in, Water Capacity (90%): 14,364 Gal, Hayward SP1091WM Dyna-Skim Above Ground Pool Skimmer Kit
    Intex 2650 GPH Sand Filter Pump & Salt Water System CS20110
    3/4" Extruded Polystyrene Foam Board Insulation, Gorilla Floor Padding
    Borated sparkle added
    May 2012
    Las Vegas, NV
    92
    thanks, looking forward to it being installed once I get the liner replaced by intex. (too many pin hole leaks at bottom)
    so you only loose about 2 squares and is it ok to place it that high up to the top grey part?
    K-2006 TEST KIT
    Jul 2014
    Llano, TX
    75
    Mine isn't the wide mouth but the pic will give you an idea on how high you can put it.
    Intex 16 x 48 Ultra Frame, Hayward 1HP pump/Hayward 180T sand filter
    Through wall skimmer, hard plumbed, homemade fountain. To do: keep working on deck, liner during the off season.
    Build thread, in progress: http://www.troublefreepool.com/threa...e-pool-install
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Great advice and pictures. I have never seen our skimmer on an Intex Pool.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    Really?!?! Tons of us have them! It's a great upgrade. Intex apparently no longer includes a skimmer standard with their pools. So if you've got to buy one, you'd just as well spend a little bit more and get a real one. Plus the improved return eyeball and vacuum adapter are nice to have too.
    If you guys sold an adapter for the Intex hoses, you'd probably sell a bunch more. Most of us had to build our own from PVC.
    Pentair IC40 SWG
    Jun 2015
    central, LA
    3
    wide mouth works great
    18x48 ultra frame, 2150 sand filter, saltwater
    May 2012
    Las Vegas, NV
    92
    thanks everyone, I got it delivered a few days ago, and now getting my replacement liner up so possible this weekend i'll be installing it.
    Quote Originally Posted by jeffchap View Post
    i second this. it would be nice if an adapter for intex pool is included.
    Any issues if it's close to the return like your setup?
    Quote Originally Posted by KirkMc View Post
    K-2006 TEST KIT
    Jul 2014
    Llano, TX
    75
    I've got the eyeball of my return pointed away from the skimmer. The water circulates around the pool before being sucked into the skimmer.
    May 2012
    Las Vegas, NV
    92
    thank you. one more question if you don't mind. if I use the Hayward eyeball will it fit the existing return hole or do I need to cut a larger one.
    K-2006 TEST KIT
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,526
    It will fit the existing hole. You can even connect the Intex hose to it, but you'll have to add an extra rubber washer to get it to tighten down enough to not leak.
    Pentair IC40 SWG
    Jun 2016
    Pittsburgh, pa
    367
    Did you go with the WM model or the regular one in the end? Curious as i'm debating on mine
    I was going to go with the regular, seems you can still achieve about 2 blocks from the top water level if installed (and screwed into) the gray part of the liner about 1" into that area (with the regular hayward).. or is it just easier to go with WM.
    My Intex Ultra 18'52 build
    My SmartPool Solar Panel Build
    6981 Gallon + Hayward 1.5HP Matrix + 21"
    Solar S601P SmartPool 160sq feet solar panels
    Intex 7K Gallon SWG, Hayward WideMouth
