Thread: First TF-100 Test Results
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    Finally ordered my TF-100, and here are my results:
    FC 9 (but measured with the 'basic' test was 4?)
    CC .5
    pH 7.5
    CH 200
    TA 180
    CYA 60
    How does that look?
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: First TF-100 Test Results
    Glad you have the TF 100
    I am not sure why you say you have FC 9, but the basic test says 4. If your FC is really 9 using the powder and drops then the basic test would be a little darker than 5.
    TA is high. PH is within range.
    As long as PH does not rise to quickly then you can leave the TA alone. If you find it rises fast then you will want to follow the lowering total alkalinity process in the how to part of pool school.
    How does your water look?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    I honestly couldn't tell the difference in the colors between the 3 and 5 on the basic FC test, so it may just be me. Should I trust the powder/drop test over the basic?
    Water looks good.
    Wendy
    TF-100 Test Kit
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    ALWAYS use the powder/drop test for analysis ... it's your mainstay. the color test is an added bonus in the kit just to back up what test #1 is telling you. Basically just a confirmation.
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by wjaneala View Post
    Water looks good.
    Always trust the powder drop test. It is more accurate.
    Lisa
