Thread: Help Sundance Heater
    Jun 2015
    Georgia
    1
    I like to keep my Sundance Spa cool in the summer It is an Optima purchased in July 2001. Is there a way I can either totally disable the heater or change the lower limit from its current setting of 80 to 65 or 70?
    Thanks
    Bruce
    Jun 2014
    15,298
    Re: Help Sundance Heater
    Hello Vruce and welcome to TFP! I see you haven't received a reply yet on your post on your heater. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    Jun 2015
    Wildomar, California
    423
    Depending on how handy you are, you can remove the heater lines to the element, but that's involved. In the past, I've adjusted the pressure switch so the heater stays off. That works but be careful to be able to reset it. I'm only suggesting this if you are handy around electricity. The thermostat has a bottom line temp that you can change.
